Hello,
I have subtitles in English with the correct timming and sync with the audio.I also have another spanish subtitle I would like to swap.The english and spanish have same number of subtitles, and every text matches.I don't want to copy/paste and changing english texts with spanish all by hand.Does anybody know the best way to do that?
Regards,
Lucas
You say you have the subtitles are you using them with an avi file?
SubtitleWorkshop has a way to use the timings from one subtitle file and the text from a different subtitle file. I don't use that program so can't provide more details.
It would also be helpful to know if you are planing on playing this on your computer or a divx dvd player.
Yeah.SRT is the extension for both.
That is correct but you have to do that line by line.I am looking for a way to do that with a script or something like that -
No, I already said you can import the entire subtitle file at once, into timings from a different subtitle file. I've seen it mentioned here but, as I said, I don't use that program myself. If you can't figure out how to do it from reading the help file, maybe AlanHK will see your thread and explain it to you.
No you don't.
This for Subtitle Workshop version 2.51.Originally Posted by Subtitle Workshop manual
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Swap files, LiveCDs
By Ai Haibara in forum LinuxReplies: 2Last Post: 23rd Jun 2009, 21:50 -
Swap audio streams in MPeg-2
By billyygli in forum AudioReplies: 1Last Post: 10th Apr 2009, 09:31 -
Swap out video without changing anything else on a DVD-R?
By bizzybody in forum Authoring (DVD)Replies: 16Last Post: 24th Dec 2008, 04:07 -
Most convinient way to swap a HDD?
By videohalp in forum ComputerReplies: 3Last Post: 27th Jun 2008, 17:24
