When I try to make an AVCHD disc with DVDslideshowGUI 0.9.3.6, the disc is unplayable in my Panasonic BD recorder (model DMR-BD500). I get a message "incompatible disc" when I try to play it. I am able to play discs made with most other software I have tried (eg PowerDirector, DVDMovieFactory, NeroVision, etc.)
Are there some settings I need to tweak? I know the bit rate should be less than 18000 kb/s for DVD medium.
Edit
I used MediInfo on the disc and it shows MPEG2 format, not AVC, and 23.976 fps not 25. I used 1080p 1920x1080x25 (16:9) project setting.
the player usually has to have AVCHD on the front to support it
My player does say AVCHD. As I said, I am able to play AVCHD discs made with other software. The problem is that the disc made with DVDslideshowGUI is not compatible. After first posting, I found out that DVDslideshowGUI is making MPEG2 files, not MPEG4 AVC as required by the spec. My question then is how do I make MPEG4 AVC files with DVDslideshowGUI? Is it currently possible? Also I noticed that although I selected a preset with 25 fps, it made a video at 23.976. This looks like a bug, but probably is not causing the failure. The MPEG2 coding certainly is.
Should I be posting this question in the DVDslideshowGUI thread, do you think? (Currently over 1000 posts!) -
I think dvdslideshowgui only makes BLU-RAY video(mpeg2 is supported then) and not any avchd that is only avc/h264 video.
Help: No audio on created AVCHD disc
By SportsorDeath in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 02:43 -
AVCHD Disc or Blu-ray Disc?
By p_l in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Jun 2011, 20:56 -
how to make avchd disc in ps3 show what movie it is
By crazydrve in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Aug 2010, 05:28 -
DATA DISC instead of AVCHD
By jah711 in forum Blu-ray RippingReplies: 25Last Post: 14th Aug 2009, 18:00
