at the moment i only have a s video cable to connect my pc to my tv. and this cable was working fine when i was using my old tube tv but now since i got my 37 inch lcd hdtv and i connect the s video to it i only get a no signal status (sometimes i get a black screen that flickers).
i retested the cable on my old tv to make sure it wasnt the cable (cable worked fine)
when i first hooked it up i had a connection then i unplugged it and ever since then i havnt been able to get it back.
anyone know how to fix this already tried everything i knew and some stuff from online nothing has worked
ps connection is s-video to s-video
and just my luck happened on my birth day lol
Did you switch the TV to a S-video input? Other than that, turn on the TV first, then the PC. If your TV has other connections, I would try them. S-video is mediocre quality on a 37 inch TV. VGA, DVI or HDMI if your PC's video card supports them would be better.
And welcome to our forums.
and yes the tv is set to s-video.
on the computer it shows that the monitor is being extended since i can stick stuff on the other side but i cant see it on the tv it just say No Signal.
it stopped working when i unplugged it and hooked up vga cables to it on a different computer since the vga cord wasnt long enough to reach with this computer.
i even hooked it up to my non hdtv and it works fine i just plug it in a boom its there.
and when the tv was right out of the box everything was working fine when i plugged it in the very first time.
but if we cant figure it out its all good just ganna spend an arm a leg for a long vga cable lol plus the adaptersince my computer is only duel vgi and s videoLast edited by detroitx; 1st May 2010 at 04:39.
It probably isn't an HDTV problem. It is a computer display card problem.
Check the card instructions for TV discovery. Most of them require a reboot of the computer with the TV on.
S-Video will look awful on an HDTV. Use VGA (or DVI-D/HDMI).Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
its not the computer or the cable since it works when its hooked up to my crt tv
and i know writing is blurry but its alright for movies -
You might take a look at Monoprice for cables if S-video doesn't work out. They have 25' VGA cables for less than $8US.
They ship about anywhere.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10201
problem getting vga to work with hdtv
By GetYourShineBox in forum Newbie / General discussionsReplies: 16Last Post: 26th Feb 2010, 16:42 -
TS HDTV Encoding and strange problem
By Robertus in forum DVB / IPTVReplies: 11Last Post: 15th Jul 2009, 11:01 -
Problem using HDTV for computer screen
By beavs in forum DVB / IPTVReplies: 34Last Post: 17th Sep 2008, 01:07 -
Problem with my Philips 29PT8836 HDTV
By coolguy12374 in forum DVB / IPTVReplies: 1Last Post: 30th Jul 2008, 21:47 -
Magnavox MDV453 to HDTV problem
By ottersfans in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Aug 2007, 07:36
