Hi! I'm a fairly new recording technician learning the ropes and all that with my university music department.
I've got several people from our department that want a DVD copy of their recital performances this semester. We webcast everything from our recital hall, but the quality isn't very good for putting on a DVD. I'm wondering if anyone knows a good way to touch it up and make it nicer to put on a DVD to give to these people?
My camera is hooked to the computer via VC-500 "OneTouch Video Capture" and we webcast through Windows Media Encoder. I'm going to hook the camera through the FireWire port, but I don't currently have one yet. On the computer, we have several programs for video editing:
1. VirtualDub
2. WME
3. Ulead DVD (whatever it is called??)
4. Windows Movie Maker
I've been trying different filters to get rid of some of the blocking, perhaps interlacing, but I'm not sure what to do... Any suggestions? (Screen Shots Below - I'm also a visual learner!)
Any advice is appreciated. Thanks!!
Take one of your regular recordings and drop it into MediaInfo and post a screenshot. Or post a short representative sample. It helps a lot to know what format and what parameters the video has. In general, filtering may remove some of the noise, but it will also generally remove some of the video quality. You need a high quality source video to make a decent looking DVD.
A DVD is interlaced, so you don't want to be removing that. Interlaced video may look bad on a computer monitor if you don't use a proper player. Blocking is usually caused by encoding at too low a bitrate.
And welcome to our forums.
Garbage in, garbage out.
While filtering can improve, this situation is not likely to yield much for results.Want my help? Ask here! (not via PM!)
You should record the performance on the camcorder, then later transfer to the computer via Firewire (IEEE-1394), then author a DVD with your ULead (Corel) DVD movie factory software.
http://www.kiva.org/about -
I have a VC500.
A couple of things....... I'm not sure that I would use the VC500 for this particular application you are describing unless you have a relatively good computer(at least dual core or better). Even then I would still try a couple of other options.
If you do want to continue using the VC500 though....... are you using the highest quality settings in it for recording(the DVD quality setting)? If so great. If not, then go under settings---->record---->then click on "DVD."
....... other options besides the VC500
First, the firewire direct to the PC is a very good choice. I would start with that. Get some software to capture the firewire feed and you should see a big improvement over what you are currently getting.
A second possibility for you would be to get a DVD recorder with a firewire input. You should be able to find a good one at any electronics store for 150 bucks or less(I paid less than 100 for mine).
Here is a comprehensive list of DVD recorders from Cnet for you to look at.
http://reviews.cnet.com/dvd-recorders/?filter=501414_5266462_&tag=mncol;srt&sort=lowPrice9+asc
The main benefit with a recorder is that it would create your DVD for you as opposed to you having to author the DVD yourself with your computer. If you have lots of different DVD's to do then this could save you some time. Another side benefit is that the DVD recorder is more portable than a computer. And lastly, it would be handling some of the work for you while your computer would be free to do other things(such as making extra copies of the DVD's or whatever).
TCMy Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 02:06 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
video quality to movie quality
By pitta1990 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2007, 00:31
