Hi everyone
I have just brought a second hand JVC HR-S8700EK S-VHS Video Recorder for doing some video transfer and the colour and quality is fantastic.
This problem is I keep getting what appear to be random black lines appearing.
Has anyone else had this problem?
Any help is much appreciated
If they're single lines streaking away from high contrast edges in the picture, they're due to head wear - either on the original record deck, or on this playback deck.
Otherwise, no idea.
(your image isn't showing here). EDIT: now it is! Yes, worn heads.
Cheers,
David. -
The deck may be damaged.
First impression is worn heads to me as well. Would look at replacing these and if it's worth it for you.
If the Light ain't Bright, It ain't Right!! -
Worn heads would essentially be damage. Must replace worn heads.
Restoring VHS (Tracking and Scan Lines) Random Pulses
By Deter in forum RestorationReplies: 44Last Post: 27th Feb 2012, 00:09 -
Fixing Random Lines in a Video
By DJUnReaL in forum EditingReplies: 3Last Post: 6th May 2010, 17:08 -
AVI with many black lines (may be black fields)
By jarhead104 in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2009, 06:36 -
AVerMedia A180 input capture problems - random short horizontal lines
By Rezolution11 in forum Capturing and VCRReplies: 0Last Post: 17th Dec 2008, 14:25 -
Bright horizontal random lines in 8 mm Camcorder Video
By axhack in forum RestorationReplies: 4Last Post: 11th Jan 2008, 21:05
