I have been using mkv to vob for a long time and it worked for all my videos no problem. but recently i re-installed my OS and so i put a new install of mkvtovob. here is the problem: file will begin to convert it shows that its dts to ac3, then muxing, then finished! at first i thought everything was good, but when i went to the actual file it was only 200 mb's and only six minutes long. what did i do wrong? i used the same steps and setting as i always used....
1. full release name: BBC.Life.E01.Challenges.of.life
2. View/Text of original file:
General
Complete name : C:\Users\Public\Videos\Sample Videos\BBC.Life.E01.Challenges.of.life.2009.1080p-CHD.Jatin17.mkv
Format : Matroska
File size : 6.53 GiB
Duration : 58mn 33s
Overall bit rate : 16.0 Mbps
Encoded date : UTC 2009-12-19 04:32:16
Writing application : mkvmerge v2.9.9 ('Tutu') built on Nov 25 2009 21:13:32
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 33s
Bit rate : 14.1 Mbps
Nominal bit rate : 14.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.273
Stream size : 5.79 GiB (89%)
Title : BBC.Life.E01.2009.BluRay.1080p.DTS.x264-CHD
Writing library : x264 core 80 r1373 4322f63
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.1:0.2 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=14463 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=2:0.80
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 58mn 33s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 632 MiB (9%)
Title : DTS Hi-Res Core 5.1ch 1509k
Language : English
Closed Thread
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 02:07 -
Can't play audio from avi made from mkvtovob for ps3
By User81 in forum AudioReplies: 1Last Post: 25th Feb 2011, 03:45 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
MKV to PS3
By WinSpecToR in forum Video ConversionReplies: 3Last Post: 10th Aug 2008, 15:38 -
Problem Converting MKV file with MKVtoVOB
By AllenM in forum Video ConversionReplies: 5Last Post: 2nd Mar 2008, 12:59
