We have a computer running windows xp pro.
Every couple of minutes a little window pops up in the lower right of the screen with the following message: "ntoskrnl.exe has been blocked from accessing the internet"
We would post an image of the little box but it does'nt stay visible long enough to capture.
Is this something to be concerned about?
Sounds like it's time to do a virus scan. Ntoskrnl.exe is a valid XP file but it can be corrupted by viruses. Undwer normal circumstances you shouldn't be seeing any window referring to this file.
Jerry M -
ntoskrnl translates as NT OS (Operating System) Kernel : http://en.wikipedia.org/wiki/Ntoskrnl
You might look here for a possible fix: http://www.computerhope.com/issues/ch000646.htm
If it wasn't working, the computer wouldn't boot, so another explanation is a virus or malware causing the problem or the popup. If it wasn't working you would usually get a MS warning of 'ntoskrnl is missing or corrupt' or similar at boot and the OS wouldn't start. What program is giving you that warning? Sounds like a anti-malware program warning, not the OS. I would run a scan with something like MalwareBytes: http://www.malwarebytes.org/mbam.php -
Do you have a software firewall installed? Or a security suite like Norton or Mcafee that includes a firewall?a little window pops up in the lower right of the screen with the following message
Sorry to take so long to wind this up but my neighbor(client) had to leave for a while. When he got back we tackled this problem again.
Here is what we did. We went into safe mode and ran three registry cleaners one after another, then a trojan remover, then an antivirus, then an antispyware. We then rebooted and the problem was no more.
So we do not know what caused the problem nor what fixed it.
Question about how to modify exe file
By jimdagys in forum ComputerReplies: 9Last Post: 29th Oct 2011, 17:59 -
Question about how antivirus stops autorun/exe on USB
By jimdagys in forum ComputerReplies: 5Last Post: 23rd Feb 2010, 17:19 -
Newbie question on sony vegas, and x264.exe
By Asday in forum Video ConversionReplies: 5Last Post: 15th Feb 2010, 14:20 -
question about viruses attacking exe (install) files
By jimdagys in forum ComputerReplies: 4Last Post: 19th Apr 2008, 09:02 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
