....firstly b4 i had installed nimo package i had da playa and its codecs installed an had updated my mpeg4 using win media player...everything was fine....then i had installed a programme called name it somehow it cause purple coloration when i encoded avi to mpeg....so i read the forum and used tmpegen and changed the environmental settings...but at the same time after i had installed nimo....i noticed dat when i playback avi amc and dvi rips using the nimo's microcrap mpeg4 codec and the divx dvd codec...the pictures were very dark.....although the edeges were sharper...but when it came to the regions, everything was just 1 shade of black....i couldnt see a thing...and i think the pictures got blockier...pls help ...i need to know how to change the colour settings...tried changing monitor settings but not much help...has it got anything to do with the yuv colour renderer thing? :(
Hi Codecs causes a' lot of problems....Purpur colors ?? Have you got
Angel potions codecs installed ?? Remove it.. If you download diffrent Prog's, Players, demos....etc.. they might install diffrent codecs creating problems.
Or....uninstall all your codecs.....Only install Nimo codec pack and update codecs throu your MediaPlayer.......Works fine for me...
Good Luck -
WARNING!!!!! If you don't have a Matrox G400 video card make sure you deselect the divxg400 filter from the list of things to be installed
Saw this on Nimo Codec Pack's Page........
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 05:34 -
Screen capping on computer, XviD codec misbehaving?
By CursedLemon in forum Capturing and VCRReplies: 4Last Post: 13th May 2011, 00:43 -
I think i may have just screwed up my pc next door....
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2009, 01:13 -
ratio / format / codec problems, pls help!
By phaedrus in forum Video ConversionReplies: 5Last Post: 8th Jun 2008, 07:57 -
DVD Plays fine on computer but is screwed up on standalones
By jalopy6 in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 09:17
