i have DVD fab works great on all my coping so i buy a bdr-205 pioneer and i cant get it to copy it comes fail or media faild i have tried two differnt brands the last one Verbatim bd-r
How about you slow down, take you time, type clearly, and give some details on what you are trying to do.
Include the steps, the programs and the process.
You are using DVDFab to rip the disc, but then you cannot burn it successfully ? Yes ?
What are you burning with ?
If you aren't burning with Imgburn you are just wasting your time.Read my blog here.
Thanks for responding I baught DVDFAB about 1/2 year ago and i am very happy with them i started backing up all my dvds now i have lot of blurays so i recently baught a bluray writer a pioneer bdr-205bk it seemed liked a good unit? i was able to install it in my pc empty slot i tested it out seems ok it records a dvd just fine i baught some blank 25gb because dvdfab said it would shrink a movie to fit? on the regular dvds i click copy and its done very easy but on this bluray i can't get it to copy it has come up several differn't times with erra it seems like its going to work it will copy it to to hard drive but it won"t transfer. after it analized it finds the blank bd says detecting writable disc . then a window pops up faild to burn!try again now with the same blank now is says this is not a writable disc i in stall a new blank then it starts all over again same problem? sometimes a window pops up says (you don't have sufficint right to perfom this operation) i emailed dvdfab at first they said i had bad blanks they recmended Verbatim. i baught them and now they dont work. they gave me videohelp web site so here i am i am not even sure how to work this site. but i am trying . what is Imgburn somthing like dvdfab something else i need to buy??
Thanks Todd
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39 -
Help copying 3d Bluray!
By Makka in forum Blu-ray RippingReplies: 1Last Post: 27th Nov 2011, 04:54 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 12:29 -
How to re-author back to bluray from BDMV bluray structure?
By eummagic in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Dec 2010, 22:14 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05
