I just purchased the ACerTV HD DVR on a machine running windows 7 64bit with the provided drivers and AverMedia Center CD.
I can hook up rca, s-video, component, and HDMI from from my various electronics and it works fine.
The problem I have is when taking the video feed from an 1920x1080p medical grade camera from a DVI connector and using a DVI -> HDMI converter I just get a black screen in the aver media center.
I can hook this to a TV with this configuration and using the provided DVI cable and it works fine.
Is this a possible sign of HDCP?
What else could be the problem?
I don't think so as it the camera shouldn't use any HDCP on the dvi output.
Have you connected anything else with dvi to hdmi converter and got it to work? -
Im gonna try that today. I did notice that the HDMI converter I have doesn't have the 4 pins around the horizontal "ground", any suspicions there?
I also tried using a straight through dvi to hdmi and it didn't work...
Any other Ideas would be appreciated -
Figured it out, the camera is 1080p and cannot be lowered
Is there any way to take a 1080p DVI signal and force it to lower so my capture card can accept it?
I looked around at some blackmagic cards and they still dont accept 1080p... Do they even make them? -
AVerTV HD DVR can capture HD video up to 1080i on both USB and PCIe model and far I know of there no low cost ver that support 1080P you have look at more of a Professional Grade Capture device
NOKYARD I do belive he ref to PCIe ver but if it is the USB model then your rigth.
AverTV HD DVR spec?
By gshock in forum Capturing and VCRReplies: 2Last Post: 14th Jan 2012, 23:11 -
DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTV
By asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 10:22 -
Laptop dvi / hdmi connection to HDTV screen flicker black
By vettesea in forum DVB / IPTVReplies: 0Last Post: 24th Apr 2011, 15:35 -
Screen turn black when my Pioneer DVR-330 plays my homemade DVD-video
By dcmwong in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Dec 2007, 13:58 -
By dcmwong in forum Authoring (DVD)Replies: 1Last Post: 6th Dec 2007, 10:58
