Hi guys, long time since my last post. Been working in florida.
I,m having a little problem in convrting an mp4 file to an avi.
I,m trying to convert with winff, which i,ve used before with
success. My problem is that when i convert and play the video
back it looks like my tv is set to 4.3 with black edges either side
of my tv.
Any ideas or settings that i should use with winff so that i can convert
and play in 16.9.
Any help or advice would be great.
P.S. I,m still a bit of a newbe.
Try convert it to 16:9 resolution/video size, like 640x360.
Or try change the avi display aspect ratio to 16:9 with mpeg4 modifier. But the player might ignore it. -
Hi thanks baldrick for quick reply.
Can you tell me, is 640x360 video size the actual setting for 16.9.
What i'm trying to say is would i have to do few conversions with different
video sizes to see whats best. If so it's not a problem.
Thanks again for quick reply -
What is your source video size?
It's called square pixel aspect ratio if you have the video size the same size as the display aspect ratio. 640/360 = 16/9. If you make an avi it's best to make the square pixel aspect ratio same as the display aspect ratio. -
Hi again,
Ok the this is the only info i have on the movie file.
Format: H.264/MPEG-4 AVC
Bitrate:1340 kbps
Framerate:23.976 FPS
Encoder: x264
Resolution:720x400
Aspect Ratio:16:9
Advanced Encoding: 2-Pass Encoding
sorry for late reply. Me internet playing up a bit (AOL)
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 15:46 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 13:32 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 20:06 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 02:44
