I've looked everywhere imaginable to find drivers for this camcorder and no luck. Canon no longer supports (4 yrs old camcorder) and googling canon drivers just gets me goofball sites who want me to sign up for monthly programs to provide drivers.
Windows XP pro doesn't even find the camera--using usb cable. I eventually need to get a firewire cable. Would the firewire make a difference????
	i think it's a miniDV tape cam. if so the firewire connection is the only way to get the video off the cam, as the usb was used for web streaming and still picture transfer only. --
	Have you emailed cannon to request the drivers? I'm sure they have them somewhere. You may end up having to pay for a disc to be shipped to you but they have to drivers for it. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	There are no drivers needed for IEEE-1394 (Firewire) transfer. XP supports DV natively.
 I suggest you use WinDV but Movie Maker will also capture the digital stream.
 If XP can't see the stills using USB, you may need Canon drivers or upgrade to Vista/Win7.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  Canon Elura - Tape capture between models doesn't work Help?By jbrajuka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Nov 2010, 06:58
  Help; Capture Locking Up with Canon Elura 90 DVBy bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 23:37
  Elura 70 Capturing DV to laptop with USB ports onlyBy knighttknight in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 13:15
  Canon Rebel xti + Canon HV30 vs. Canon Rebel T2iBy assman24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jun 2010, 12:47
  Canon ip6700D printer driversBy kenmo in forum LinuxReplies: 0Last Post: 7th Apr 2008, 13:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
