OK, so ive been converting some AVIs to make them smaller, ive just been lowering the bit rate from 1000 to about 750 and they end up about 260mb. these are 40 minute long tv shows.
i ripped a dvd yesterday to put on my ipod, (m4v) it was the pilot of a tv show and was 1hr15 and i used a constant quality option to encode it and it ended up with an average bit rate of about 659.
but its 441mb
now its only 35mins longer than the other tv shows but its so much bigger
does the container make a difference to the file size?
edit: ok ive just looked at the codec info in VLC and for some reason it decided NOT to use h.264 when i ripped the dvd, not sure why but i told it to.
ill redo it in h.264 and see what it says then
Results 1 to 11 of 11
Err...if a 260mb file is 40min, then you'd expect a 75min file with the same bitrate to be 488mb. 260/40 * 75 = 488. Simple math. The codec chosen is irrelevant.
ah yes, sorry, i got confused, the sample i made had a bitrate of only 300 ish then i checked the one for this then edited this post withouth thinking. cheers
Not so much bigger? It's almost twice as big(40minutes + 35 minutes...) so it should be about twice as big in file size.
The container will make a difference to the file size because of different overhead but not that much. (see http://www.alexander-noe.com/video/amg/en_overhead_comparison.html ) -
really?
because the ones i've encoded using xmedia recode actually say h264 on them
this codec lark is confusing lol
thanks for your help
Converting M4V to AVI
By tj3 in forum Video ConversionReplies: 6Last Post: 15th Dec 2016, 05:24 -
DV-AVI to M4V issie using Handbreak
By Marli in forum Video ConversionReplies: 2Last Post: 5th May 2011, 08:44 -
What is out there? M4V to AVI or WMV
By ingeborgdot in forum Video ConversionReplies: 4Last Post: 30th Apr 2010, 19:41 -
M4V to AVI or MPEG??
By Nikolaiwww in forum Video ConversionReplies: 7Last Post: 5th Oct 2009, 06:38 -
m4v > avi or mp4
By empershand in forum ffmpegX general discussionReplies: 2Last Post: 17th Mar 2008, 16:55
