I have AVI's captured with HuffYUV and Lagarith which I've coverted using the DVD standard format in TMPGEnc. This has given me .MPG files.
Can I takes these files DVD-Video format without them having to be re-encoded? Are there any freeware programs to do this? If not, what's the best pay program to use?
Is there some other way I should convert them in TMPGEnc Xpress, or perhaps skip using TMPGEnc Xpress? I also have ConvertXtoDVD available, but I assumed TMPGEnc Xpress was a better conversion tool, so I started with that.
	Yes, there are some free dvd authoring programs like dvdstyler, guifordvdauthor and dvd flick(be sure to set to not reconvert mpg/dvd compliant streams in dvd flick).
 Or use the all-in-one dvd converter AVStoDVD, use the builtin hcencoder and you should get at least or even a bit better quality than tmpgenc xpress.
  TMPGEnc DVD Author vs XpressBy likwid8 in forum Authoring (DVD)Replies: 6Last Post: 20th Oct 2010, 11:56
  TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23
  BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41
  difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
  LaserDisc to DVD with TmpgEnc Xpress 4.0By sapulidi in forum RestorationReplies: 5Last Post: 16th May 2007, 13:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
