I'd like advice on how to convert Hi8 NTSC (tapes) to DV/DVCAM PAL to get the best possible results.
I intend to edit this footage on Final Cut Pro with other PAL material.
Thanks.
I think you have no other way than using a capture card...
If you could work in a Windows envirorment I'd suggest you something like Virtual Dub for capturing and converting...
In Final Cut you can mix every type/size/framerate you want and the program itself will provide a professional conversion of the footage...
Just be sure while you import to choose a lossless (or very little compressed) format...
That's my point of view...
Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
By frappefan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Dec 2010, 14:18 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 13:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 01:34 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
