Hi, I have Media Pllayer Classic Home Cinema 1.3.1752.0, and when I select Remember window size in the options it doesnt work. Every time I open the player It changes the size to the video resolution.
What can i do? I've tried a lot of combinations, and it use to work on simple Media player classik.
Thanks!!
Try a newer or older version and see if makes any difference.
Revision 1812 - Directory Listing
Modified Mon Apr 26 23:26:42 2010 UTC (45 hours, 45 minutes ago) by kinddragon Fixed options "Remember last window position/size" (introduced in revision 1707)
Based on this fix, get a version 1812 or newer. -
Or download latest beta from https://www.videohelp.com/download/mplayerc_homecinema_v1.3.1821beta.zip or the russian site http://www.xvidvideo.ru/media-player-classic-home-cinema-x86-x64
thanks to all of you, and sorry for answering late, and try all the things you told me!
Default window size for video file changes after conversion.
By dodo23 in forum Video ConversionReplies: 7Last Post: 25th Aug 2010, 19:26 -
Problem with window size when encode mov to flv
By amedeop in forum ffmpegX general discussionReplies: 1Last Post: 16th Feb 2010, 18:23 -
video window frame refresh not working
By smithpgr in forum Capturing and VCRReplies: 0Last Post: 26th Nov 2009, 10:05 -
PowerDVD - saving window size?
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2008, 00:11 -
Window size of video capture too small
By rapattack in forum Capturing and VCRReplies: 2Last Post: 16th May 2008, 09:38
