Hi everyone, does anyone have experience with an Easycap usb capture device?. I was getting very large files when I tried to transfer video from my VCR to computer. I left it and now am going to try again. If anyone is geeting excellent transfers with this unit I would welcome advice. I got the images onto the computer fine but the transfer ate so much disc space that the computer crashed, we are talking about 50 gig for about 30 to 45 minutes transfer. I think it is suppoed to be in the 13 Gig region for an hours video transfer. All advice and assistance welcomed.
Regards
Visionman
Health IS the first Wealth------So do not strain your eyes!
Thanks hech54, I will reinstall and give it another go with your comments in mind, thanks.
Since my original post I have searched the site and a few posts have indicatred that this device is primarily a short capture device, ideal for uploading video onto the web. Don’t be surprised if you see a post regarding “whats a good pci capture card to buy “ Cheers.
visionmanHealth IS the first Wealth------So do not strain your eyes! -
the Easy cap should have no size limits...
You just need to capture in mpeg2 rather than the DV AVI you captured. There was probably no need to re-install it should be an option with the software you use when capturing -
Full D1 (720x576, 25 fps) video capture as:
uncompressed RGB: 112 GB/hr
uncompressed YUY2: 75 GB/hr
DV: 13 GB/hr
With MJPEG or MPEG compression the size will vary depending on the quality/bitrate chosen. -
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum Capturing and VCRReplies: 4Last Post: 21st Nov 2010, 22:22 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 20:51 -
Easycap Capture, USB 2.0
By Kimmytattoo in forum Capturing and VCRReplies: 2Last Post: 16th Jan 2010, 14:13 -
EasyCAP 2.0 USB = No Sound on Capture????
By williamgibbs in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2009, 08:15 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 10:06
