i want to erase the audio from AVI video clips and replace it with different audio. what should i do what should i use?
i am trying to do it with AVS video editor but cant get it to work.
i have also tried it with AVS audio editor but for some reason it wont do videos.
help!
also have searched through google and cant find the right answer ime looking for it just gave me lists of different programmes to use and i dont know how to use them and it wants me to buy them and i have no money.
you can use avimux-gui to replace audio stream. Other options are virtualdub, or avidemux . All free
now i want to remove the studio badge from the video. it has a badge in the bottom corner of the screen which shows all the way through the video it saiz MIRAMAX or something like that how do i get rid of it??
Like a watermark? If so, look up "logo removal" threads, there are about a dozen or so guides on this site alone...
It requires that you cover it up with something, or blurring the section, and this requires re-encoding
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:32 -
Merging AVI Clips
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 26th Nov 2007, 16:10 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:52
