after i encoded the avi-file i tmpgenc the mpg-file had only audio...WHY???
Results 1 to 9 of 9
No clue, but sounds like a problem I'm having where neither TMPG Enc nor Virtual Dub recognize my DivX avi files.
I've tinkered and tinkered and my only idea left would be to convert the .avi to something else, but nothing I have even recognizes the video in the .avi!
Plz help."Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!"
...don't ask
-Markfuscius -
maybe it's because you might have encoded it to mpeg-2 and you don't have any dvd software installed. 8)
need it to watch svcd's I think. -
That's not what's goin on with me...I have DivX .avis that run fine...in DivX player and nowhere else. You can only get them as DivX .avi becuz they're anime fansubs.
I'm not sure, but I think windows isn't recognizing the DivX Codec...and that causes all of my video related problems. The problem is that I have no clue how to get windows to use the codec for .avi files...
thx fer help..."Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!"
...don't ask
-Markfuscius -
yep the file your encoding is useing a codec that tmpge cant use
i downloaded some files and that happened to me
the file was encoded useing ms mpeg 4 v3
so i had to convert it useing virtualdub to ms mpeg 4 v2
so just covert the file to a dif codec -
I'm using WinXp had the same problem, i installed codec 3.11a then the new 5.0 and it now converts the avi to mpg fine, hope it works for you also.
I've got 5.0 and, sadly, its not working.
See, I have the same no-vid problem with virtual dub, but I'll give that a try. Thanks fer the help...any other suggestions would be grand."Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!"
...don't ask
-Markfuscius -
Yeah...vdub's not working either...
...don't ask
-Markfuscius -
I've fixed it!
And almost on accident!
I decided to poke around on cnet.downloads to try'n find an avi editor, downloaded winVDR barely understanding what it was talking about, installed it, and now TMPGEnc runs beautifully! Time to burn my first VCD!!! ^_^
Thx fer all your guys' help!"Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!"
...don't ask
-Markfuscius
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
I have a blank screen when booting
By edong in forum ComputerReplies: 4Last Post: 17th May 2010, 00:19 -
Acer Aspire 5920G blank screen
By nevar in forum ComputerReplies: 0Last Post: 14th Sep 2009, 12:53 -
ripbot264 mkv blank when full screen
By amadeus00 in forum Blu-ray RippingReplies: 2Last Post: 30th May 2009, 15:20 -
MpegStreamClip shows blank screen/needs update?
By jwnulife in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2007, 09:42
