how do i make .srt files into permanent movies.
i can get the subtitles to work when the video file is in the same folder as the .srt file but i want to load my videos with subtitles onto youtube.
i have tried using ffdshow ,, ,vobsub ,, and TMPGenc which all have long long lengthy instructions on different forums with bits missing but ultimately they dont work!
help
YouTube allows for separate and selectable subtitles from SRT subs. After uploading your video there's a box to check for uploading the subs.
If that's not enough well, you didn't really tell us anything about the source videos you want to add the subs to. If DVD or another AVI, AutoGK does a good job. Here's Baldrick's guide:
https://forum.videohelp.com/threads/256625-How-to-add-permanent-subtitles-with-AutoGK-a...I-DivX-or-XviD
For other kinds of videos, it might help if you told us what kinds you're trying to sub. I'd recommend XviD4PSP, but wouldn't want to be blamed after you couldn't make it work.
That's right, there's no way any of your problems could be your fault, but have to be the fault of the guide writers....but ultimately they dont work! -
I wouldn't necessarily rule out user error, but to be fair some of the guides on other websites and forums do leave out critical information and less experienced people may not have enough experience to fill in the gaps on their own.
its ok ive done it.
but now i want to cut out the audio on a video and replace it with different audio i am trying it with AVS video editor but i dont know how to do it.
help.
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
How to make DVD with Video .avi and Subtitle .srt?
By lukanino in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2012, 14:51 -
Does Plex support .srt subtitle files?
By dutchgirl in forum SubtitleReplies: 0Last Post: 3rd Apr 2010, 12:54 -
How do i add two .srt files into Subtitle Workshop??
By emilroh in forum SubtitleReplies: 1Last Post: 16th Feb 2009, 14:41 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
