	What is your goal ? watching or converting ? How did you extract : from dvd directly or after ripping it ?
	My ultimate goal is to extract the audio from the DVD into MP3. These are lectures. Each is about 1 hour. When I extract the MPG from the DVD using VOB2MPG, I normally get a few files of a few hours each. It's not that hugh and VideoRedo can handle it. This time, it's 1 big file, too hugh for VideoRedo. I then use other media players to try watching it to see if there is any problem with the MPG. I used VLC, Windows Media Player, etc and all of them could only read about 2 hours.
 So what can I do to extract the MPG (I also want the MPG, not just the MP3) so that they are smaller. Thanks
	VOB2MPG extracts titles, so if the DVD has one big title, you get one big mpg file. That said, the file should not be larger than the capacity of the disc, and I have edited MPG files in videoredo that are far larger than any DVD could hold.
 How long should the file be (running time) ?
 Did you try using DVD Decrypter (or DVDfab HD Decrypter to get the files onto your HDD, then using VOB2MPG ?
 VOB2MPG shows you what it has found, so what did it say ?Read my blog here.
  mpg-videos 'burnable' on 'viewable' DVD-R without converting process?By video-fan in forum Authoring (DVD)Replies: 8Last Post: 12th Oct 2011, 08:03
  best program for separating one large MPG file to several sequential filesBy nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 18:09
  MPG files are too largeBy sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 06:59
  Large size difference in mov and mpg, no apparent loss of quality.By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 10:19
  Spliting large mpg file into clips and saving each clip as a mpg file ?By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
