How can I get the framecunt, or play length of an audio clip without creating a blank video clip and mixing the audio with it? I want to know if this is possible without using AudioDub.
Audio duration in seconds is given by AudioLengthF(clip)/AudioRate(clip).
http://avisynth.org/mediawiki/Clip_properties
To get corresponding frame count, multiply this by the frame rate (FrameRate(clip), if the clip has video).
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 02:17 -
Trying to get AudioDub to work with .mp4 and .wav!!!!!
By Nagashi in forum EditingReplies: 1Last Post: 29th Dec 2010, 18:33 -
Clip Length Changing?
By Problematique in forum ffmpegX general discussionReplies: 1Last Post: 18th Nov 2009, 15:26
