Any links for troubleshooting? I'm 3 days into this, 16 hours or so.
WindowsMM and MPC got video, but no audio. Linux has not gotten vids or audio.
I got coax directly from VCR/DVD player into the card input.
Help?
Results 1 to 10 of 10
Who needs time for Linux? You guys claim to be smarter than us.
http://www.kiva.org/about -
Smarter? Only thing I learned in the last 3 days was that Foxconn mis-labled the CMOS jumper pins on this new board, AND manual.
Ever try booting a machine with jumper pins in CLEAR CMOS???
Sorry was watching Jack Bauer on Hulu. Seemed more important at the time.
OK finished 4 hours of 24.
What are your detailed hardware specs? Last I looked there were no 64 bit drivers for the PVR series. Still don't see any.
http://www.hauppauge.com/site/support/support.html
The MythTV people claim Linux support via the Video4Linux project
http://www.mythtv.org/wiki/Hauppauge_PVR-500Recommends: Kiva.org - Loans that change lives.
I saw that x64 wasn't supported; this might be why I got video with XP 32bit booted up (video in WMM, and MPC, with XPPro).
Surely there's open source support by now; I think I have only settings adjustment necessary, and I'm not knowing what to look for...
Mobo is Foxconn A7DA-S
Athlon II X3 440
2Gmemsticks
Tuner card Haup PVR (500?/ has cx23416 chipset). -
Are you using the Tuner or Video input
If it is the Video input did hook up the audio to the 500?.
Also keep that this is Hardware Encoder min apps do not work use WinTV 2000/6 or 7
As for linux you want to go here
http://ivtvdriver.org/ -
Don't know.
Do you mean, [VLC] Open / Open Capture Device / Video4Linux (or PVR) ? Yes, tried both, but I don't know if all settings for each were correct by default.
Not sure what you're asking here either... I have coax into video coax input on 500, direct from VCR/DVD (signal confirmed), but NO audio input connected to 500. Is audio not integrated with coax?If it is the Video input did hook up the audio to the 500?.
Min applications? You mean the native applications? So I need 3rd party apps? Such as?Also keep that this is Hardware Encoder min apps do not work use WinTV 2000/6 or 7
Driver/firmware links are either outdated, or run me into a do-loop, or might be leading me to load older utilities, when I might have nothing more than a configuration error...As for linux you want to go here
Capture with Hauppauge WinTV PVR.500 VHS
By Asesinato in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2012, 11:33 -
Hauppauge HD PVR (Capture PC gameplay)
By TommyGun in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2010, 10:50 -
Capture from your Hauppauge HD-PVR to your Mac
By cnolan011 in forum MacReplies: 1Last Post: 14th Jan 2009, 01:34 -
Help with Hauppauge PVR 500.
By seymoria in forum Capturing and VCRReplies: 0Last Post: 24th Jul 2008, 05:27 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 15:05
