I have a mkv file that is 4.37gb which is perfect for a dvd disk, but my blu-ray player only plays avchd disks and I only have normal dvd disks. I want to know how to fit it onto a normal dvd disk without changing the audio because the audio quality is already kind of low. Thanks
You will have to re-encode the video. Chances are that the file is no compliant, in that it;s resolution will have been cropped, so you will have to re-encode to correct for that as well. Multi-AVCHD or AVCHDCoder will both happily make sure your video is compliant, and keep you existing audio (assuming it is also compliant). AVCHDCoder will automatically calculate the correct video bitrate for you, Multi-AVCHD tends to produce oversize discs using it's own calculations, so use an external bitrate calculator and manually enter a bitrate in the Transcode settings.
Read my blog here.
Thanks for the info, but I do not know about bit rates and stuff I just know the higher the bit rate the better quality. The bit rate for the video is 3588 kb/s and what should I change it to?
alright i tried AVCHDCoder but its been taking a very long time like its been 2 hours and the encoding pass 1 is 0%, so I'm just wondering is there any other program to reduce the bitrate. And I do not know how to use multiavchd to reduce bitrate.
Multi-AVCHD - add a file, then click on the file and it will open the file properties. Click on Transcode, and here you can set a video bitrate.
If your computer specs are correct, don't expect to see any conversion finish in under 5- 6 hours, even at the lowest quality settings. I encode on a base level quad core (Q6600) and a high quality AVCHDCoder encode takes 3- 4 hours, with Multi-AVCHD taking around the same on a two-pass fast encode.Read my blog here.
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55 -
Set default MKV size in DVDfab for a 4.37GB DVD disc?
By iamkatpeeler in forum Authoring (Blu-ray)Replies: 7Last Post: 24th Apr 2011, 10:59 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
mkv file too big for avchd
By mysts in forum Authoring (Blu-ray)Replies: 5Last Post: 3rd Nov 2009, 22:07 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34
