Ok, I've tried BeSweet - didn't work, got the downmix overflow error (no matter what settings I used) and there was a LOT of static with the result. I have audio from an NTSC file that I need to mux to a PAL video - both have different runtimes. I thought about just converting the NTSC video file to PAL, but that doesn't change the runtimes (at least not using TMPGEnc or MainConcept - haven't tried it with VD/VDMod, don't use them for much conversion).
Any ideas?
Thanks!
(Oh, and if it helps any, I don't need to keep it as AC3)
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
PAL AC3 to NTSC AC3
By USiT2009 in forum AudioReplies: 6Last Post: 6th Sep 2009, 16:55 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 19:03 -
Convert 29.967 to 29.970
By jin007 in forum Newbie / General discussionsReplies: 11Last Post: 17th Jul 2008, 13:09 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45
