Hello! I'm having a bit of a problem here. I finally got my Divx AVI movie file converted into DVD ffmpeg format and ended up with the movie.DVD folder with the Video_TS and Audio_TS folders inside.
However, I previewed the movie in VLC and it had a terrible high-pitched screeching noise during the entire film. I thought it might have just been VLC's fault so I burned the DVD in Toast, popped it into my PS3 and the same thing happened. The video played perfectly but the audio was just the screeching noise. I could still hear the original audio from the film very lightly, but the screeching basically blocked it out.
I previewed the original AVI file in VLC and Quicktime and the video and audio were both perfect. It seems something went wrong in the conversion process.
Thanks so much!
wow, i figured it out. it had to be either one of the these 2 things that caused this:
#1: after converting the movie the first time around I noticed the progress bar had reached 100% so I burned it. however, later on I learned that the progress bar should read "finished", not "100%". i doubt this was the problem though.
#2 (i'm guessing this was the problem): the 2nd time around I switched the Audio Channels setting to Mono because I remembered that the movie I was attempting to burn was in Mono for some reason. I burned the DVD and the sound was perfect.
High pitched background noise...
By bsuska in forum AudioReplies: 2Last Post: 25th Mar 2010, 13:15 -
Audio slightly high pitched in any player...
By Guitar3dt in forum AudioReplies: 20Last Post: 26th Nov 2009, 18:24 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 20:31 -
playing back high bitrate mkv
By swiss in forum DVD RippingReplies: 3Last Post: 4th Sep 2007, 01:41 -
A program that works like convertxtodvd , but keeps video qulaity high ?
By marinerules in forum Authoring (DVD)Replies: 7Last Post: 19th May 2007, 06:58
