Hi guys.My question is what program will help me change the aspect ratio of mkvs so that i will be able to watch movies with 2.35:1 ratio on my LCD TV in fullscreen.I'm watching the movies through the usb flash drive and the internal player doesn't have an option to zom the image.
Are the MKVs being decoded/played directly by your TV? Surely your remote allows you to select the zoom/aspect ratio?
You can change the display aspect ratio of MKVs using MKVmergeGUI, but I don't know if that is really the problem. Your TV could simply have its aspect ratio setting wrong. -
2.35:1 is wider than your screen, hence the bars. You cannot use the aspect ratio in the mkv container to change this, you will have to either use the zoom on your TV or player, or crop and re-encode the video so it fits a 16:9 (1.778:1) screen. Or learn to accept the fact that 16:9 is just one of many, many aspect ratios used in film making, and stop getting so upset about a couple of inches of black screen.
Read my blog here.
I'm watching the movies through usb and the internal player of the tv simply doesn't have any zoom option.I've tried with mkvmerge but it has no effect; i've also heard about automkv but i don't know how to use it, i'm not getting any output (pnly a temp folder).
So, the only solution is reencoding(which takes plenty of hours from which i know)?? -
All you can do is crop the sides and enlarge. Not sure what program can deal with an MKV file but take a look at avisynth and virtualdub
Many modern films shot in 2.35 format are framed to allow cropping of the sides for HDTV release and some are multi shot.
Check out http://www.widescreenmuseum.com/index.htm#main%20index for a discussion on the pro's and cons and some good illustrations.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 19:12 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 11:33 -
mkv wont play full screen. change aspect ratio?
By elimelim in forum Newbie / General discussionsReplies: 17Last Post: 19th Jul 2010, 20:21 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 11:49 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 10:21
