Cannot find a hack for this player - it's not a blu ray player, but upgarades dvds to HD. Can anyone help??
I am in the same boat...did you figure it out? I just got this DVD player and I am looking for the hack code as well.
Maybe you should have done some research BEFORE purchasing huh?
I found 2 hacks. You might give them a try.
(ensure no disc is loaded)
press <home>
Press <play/pause> 159121212005_ _ _ fill in desired code here (255 for free) followed by <play/pause>
and
1. Turn on the player from the front panel (without a disc inserted)
2. Press HDD List on remote and ensure Hard Disk is highlighted
3. Press PLAY
4. Enter 159 121 212 005 255
5. Press PLAY
6. Turn the player off
Matt -
For the DVP3570/F7:
There is no "HDD List" Button on the remote.
The procedure here does not work.
Any button other than open/close or setup gets a red "x" on the screen.
There must be a procedure that involves the "setup" menu.
I've used hacks for the DVP642, so I'm sure there's one for this thing. -
This is somewhat like buying a lottery ticket for the first time, winning 50 dollars, and then concluding that EVERY time in the future that you need 50 dollars you can just buy a lottery ticket because you will always win money that way.
All DVD players don't have hacks. There may not be a hack for this player. Hollywood has gotten just about everybody to cut back on making players that can be hacked. A few years ago it was almost impossible to find a player made by Philips anywhere in the world that could not be hacked. Now even Philips makes some players that can't be hacked. Sometimes due to hardware differences hacks may only work on models sold in other parts of the world.
Philips DVP3750/F7 Region Hack
By sunnyblueskies in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Dec 2011, 12:11 -
Philips DVP3570 need region code
By fred1902 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Aug 2010, 23:50 -
Philips 3506 region hack?
By missmyrnaloy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Jan 2009, 22:22 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 12:29 -
Philips DVP3200V/75 region hack
By Tom Sawyer in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th May 2007, 04:07
