Process I am using:
AVI captured using Lagarith in VirtualDub via ATI 750 USB. I need to cut into smaller video segments, so I mark begin/end and cut to the new section. I set VirtualDub to to "direct stream copy" for both audio and video, and then Save as AVI.
By doing this process, and given that the file is Lagarith encoded, when VirtualDub saves the new AVI, it's not re-encoding, correct? I just need to make sure I'm not inducing any additional loss by doing this.
If you use 'Direct stream copy', it's not re-encoding. Of course if you made any changes to the structure of the AVI, such as resize, trim, filtering, you would have to re-encode. But not for basic cuts and pastes.
That is correct. In Direct Stream Copy mode Virtualbud doesn't even bother to decompress the source video stream. It just passes the compressed frames to the output file. Even if it did decompress and recompress, there would be no loss of quality (unless you were converting to RGB for filtering).
Hauppauge USB live 2 capturing with virtualdub and lagarith
By rudolf016 in forum Capturing and VCRReplies: 13Last Post: 14th Apr 2012, 11:14 -
Lagarith and MJPeg Videos not playing in MPC but OK in Virtualdub ?
By blewyn in forum Software PlayingReplies: 5Last Post: 18th Jul 2011, 03:40 -
Bluray ripp to lagarith 720x405 resize VirtualDub
By Klemc in forum Video ConversionReplies: 13Last Post: 4th Aug 2010, 00:45 -
VirtualDub will not open Lagarith file
By StrobeLightEpileptic in forum EditingReplies: 14Last Post: 24th Jun 2010, 01:09 -
Lagarith in VirtualDub is increasing our Bitrate.
By Dib00 in forum Video ConversionReplies: 7Last Post: 18th Feb 2010, 19:27
