I want to join 2 video music clips together. Both are mpeg2 with ac3 6 channel audio. both can be played with the videoredoplus software separately. However i can't join them together using videoredoplus software. After investigating, I think the reason is that one clip has 6channel ac3 audio with PID80, the other clip has 6channel ac3 audio with PID
81.
How can I fix the problem so that I can join them together.
Thank you for all responses
join 2 clips of different quality
By mathmax in forum AudioReplies: 15Last Post: 6th Dec 2011, 13:46 -
Is it possible to join clips in iMovie HD
By piperpilot12w in forum MacReplies: 2Last Post: 3rd Mar 2010, 18:30 -
need to join mpg clips
By volam1 in forum EditingReplies: 9Last Post: 23rd Nov 2009, 13:21 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 21:52 -
How do i join these kind of clips?
By vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2007, 14:50
