This seems like it would be a tracking issue, but I just can't get it out. I cleaned the heads in the VCR. This shows on all tapes i playback to my computer through my ATI 750. The area in question is designated by the red box. If it's a tracking issue, I think I'm stuck with it (Short of buying another S-VHS VCR, which I'd prefer not to do). If I am stuck with it, suggestions on how I eliminate it from my captures? I could crop out the lower 8 pixels to get rid of it, but then the resolution is non-standard. What can I do after the capture to remove it while keeping a standard resolution?
Here is a 3 second, low resolution clip. Expand the window size out to see it easier.
http://www.slipoftime.com/temp/sample.avi
Just add a black border around the entire screen. There are two types of "border" tools....ones that
alter the original size and ones that don't. AviDemux has both built-in and there is a very cool plugin
for VirtualDub called Border Control.
I doubt you will actually SEE that bit of overscan on the final product but to be sure...Border It. -
All VHS recordings have that at the bottom. It's called head switching noise (though I'm not sure that's really what it is).
Wow, I guess it's really been that long since I've watched a VHS, heh. I'll see what it looks like on my TV when encoded to MPEG-2 for DVD before I decide if I'm going to do any borders.
You don't normally see it on the TV because the TV overscans the picture. You never see the very edge at any of the four sides of the picture.
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
Panasonic FS200 (AG1980) tracking / noise issue
By JoseD in forum RestorationReplies: 0Last Post: 21st Jun 2009, 18:54 -
Tracking calls on a PC
By chewie8008 in forum ComputerReplies: 1Last Post: 13th Jan 2009, 23:39 -
tracking issue
By blacktooth in forum RestorationReplies: 0Last Post: 17th Nov 2007, 00:21 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 08:11
