Using VDub and ATI 750 USB> When I go into Video/Capture Filter, the comb filter is set to 2D and when I change to 3D and hit apply, it goes back to 2D. I can change the other settings and they stay, but not this one. Anyone else have this behavior?
The USB stick version of this device doesn't feature a 3D comb filter. A little research goes a long way.
It does but it's weird. Its behavior is somewhere between Theater 550 Pro/650 and the cards that have no motion adaptive 3d comb filter. For example on static scenes it does remove dot crawl. But it doesn't fully eliminate rainbows it only reduces them.
Are you implying that PCI-e version does have the filter? -
The PCIe version does use a 3D comb filter. The USB version doesn't; I have one.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
Diamond ATI TV Wonder HD 750 USB
By Caple in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2010, 21:39 -
3D Comb Filter and Pass Thru
By RidgeShark in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Jun 2010, 23:36 -
Work-Around For Poor Hauppauge HD-PVR Comb Filter?
By dublus in forum Capturing and VCRReplies: 9Last Post: 25th Aug 2009, 19:54
