I'm trying to sync subtitles using subtitle workshop. The problem I'm facing is that even though the first and last sub is displayed at the correct time of the conversation, almost every other sub in between is out of sync. So basically it progressively changes the timing and is not consistent. If the first sub was 4 seconds slow and the last sub is also 4 seconds slow, then there are many free ware that can help sync this kind of issue. From what I read, SW is one of the few that can correct subs that are not, hmmm, evenly out of sync.
Anyone done this before? Any help to get a manual on how to use SW would also be appreciated
I guess you have downloaded subtitles? Are you then sure that subtitles are for same video source then? The video may be edited differently.
I figured how to do this on an older version of SW. The Beta version doesn't have any descriptions and thus was not sure which buttons to use! Thanks!
Of course, stable version is much better than the beta one.
Also, you can use Aegisub for that, or Time Adjuster. -
I use the Easy Subtitles Synchronizer (ESS). It is a freeware tool that repairs and synchronizes subtitles easily. Up to now it's more handy than other similar tools that I have used.
http://easysubs.blogspot.com/
subtitle workshop crashes when loading video
By stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 16:37 -
Subtitle (Workshop) and mpg video
By cyrax2006 in forum SubtitleReplies: 10Last Post: 6th Nov 2011, 15:17 -
Video image on Subtitle Workshop
By carlmart in forum SubtitleReplies: 6Last Post: 26th Sep 2011, 17:58 -
Subtitle Workshop 2.51 can't load a video
By Charmer in forum Video ConversionReplies: 9Last Post: 17th Apr 2010, 11:42 -
Subtitle Workshop does not show video
By aslan in forum SubtitleReplies: 2Last Post: 1st Apr 2009, 08:38
