My JVC HM200 camcorder creates .MTS files. I followed these instructions:
http://a8t8.spaces.live.com/blog/cns!2518DD508BB713E8!240.entry?wa=wsignin1.0&sa=15 0942360
The files do play now, but in slow motion--about 1/2 normal speed, in WMP11, with XP. I also have the KM Player installed and it plays them the same way. I know the computer can play them because I tried the Windows 7 RC and it would play normally in WMP (with the occasional dropped frame).
Any ideas here? thanks.
if your computer specs are correct the p4 3.2 is probably too slow to play it.
Yeah, if you're on a single core CPU, it's probably too slow to decode 1080p. You can disable the loop filter in whatever H.264 decoder you use, which will reduce quality but speed up decoding. You can also try the DivX H.264 decoder, which should be very fast and probably a bit faster than ffmpeg, which MPC-HC and KMPlayer rely on.
Yes, not enough CPU power, that was my thought as well. But how does WMP12/Win7 play it then? Also another detail, a while ago I DID have KM Player playing these clips normally! I have no idea what settings I was using tho; it has so many (one of the reasons I think it's the best player I've ever tried).
I tried divx player; didn't play. Tried pointing KMPlayer to use divx decoder; no change. (Tho I'm not sure I did it properly). -
Exactly what decoder is being used to play these files under KMPlayer? And how about under WMP? I know how to check the decoder being used in MPC-HC - right-click in playback window > Filters. Try to figure out what's being used in your players. If a slow decoder is being used, then you need to use another (probably by changing codec priority).
If these clips really played normally on KMPlayer, without any noticeable frame dropping, then you have a codec configuration problem.
AVCHD - join MTS files
By cmichel04 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Nov 2012, 17:30 -
Merge HD MTS (AVCHD) files
By foxnews in forum Video ConversionReplies: 9Last Post: 28th Jun 2011, 08:18 -
AVCHD MTS files - 1.6 GB on card, but only 8 MB readable
By moxiecat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 22nd Feb 2011, 14:10 -
cannot edit/play avchd .mts files from canon HG10 in pinnacle studio 14 ??
By Praun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Oct 2010, 06:57 -
(?) min system specs to play MTS avchd files thru MPClassic Home Cin 1.3 ?
By jimcornetet in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2010, 19:14
