  1. Hugo Braule
    Apr 2010
    Rio de Janeiro, Rj, Brasil
    Hi,
    I'm new around. Would like that you tell me what is wrong in the script below, if you will. A message comes and reads: "Avisynth open failure: AVI Source: couldn't locate a decompressor four fourcc (F:\aviSynh 2.5\sidebyside.avs, line 12)
    Width=720
    Height=480
    BorderColour=$000000 # White would be set to $FFFFFF
    BorderWidth=0 # Set to 0 if no border required
    clip1="cena4e.avi" # This provides the audio track. It also sets the duration of all other videos by looping or trimming their length !
    clip2="cena4f.avi"
    bw=BorderWidth
    w=720
    h=480
    clip1=AVISource("cena4e.avi").BilinearResize(w,h). Letterbox(bw,bw,bw,bw, BorderColour)
    totalframes=Framecount(clip1)
    clip2=AVISource("cena4f.avi").BilinearResize(w,h). Letterbox(bw,bw,bw,bw, BorderColour)
    StackHorizontal(clip1,clip2)
    I have ffdshow video codec, Huffiuv v.2.1.1 and some others. It used to work before. Now I've made some changes to the original script trying to figure something. Nothing works.
    The former one looks lyke this:
    Width=720
    Height=480
    a1="01.avi" # This provides the audio track. It also sets the duration of all other videos by looping or trimming their length !
    a2="02.avi"
    bw=BorderWidth
    w=720
    h=480
    a1=AVISource( a1,).BilinearResize(w,h).Letterbox(bw,bw,bw,bw, BorderColour)
    totalframes=Framecount(a1)
    a2=AVISource( a2 ).BilinearResize(w,h).Letterbox(bw,bw,bw,bw, BorderColour)
    StackHorizontal(a1,a2)
    I will appreciate any help. I have a clip to put on the air but I can't.
    thanks,
    Hugo Braule
    Jul 2009
    Spain
    This is telling you you do not have the necessary VfW codec for your source file cena4e.avi.
    Use GSpot or MediaInfo to determine which codec is used in the source.
    If it is one supported by ffdshow, you can enable it in the ffdshow VfW configuration.
  3. Hugo Braule
    Apr 2010
    Hi,
    I wish to thank you for your help. I finally understood that I can't open a codec from outside C:\. It's running. Thank you very much, Gavino.
    Hugo Braule
