I've been doing some experimenting with Avisynth to take advantage of its deinterlacing to facilitate better deshaking since I've been advised the Thalen Deshaker will work better on progressive, deinterlaced avi's. Further I've been advised it's better to convert to a lossless codec such as Huffyuv to avoid degredation from processing.
My source video is 16:9 DV, however it appears that when converting this to Huffyuv, it doesn't retain the 16:9 AR. Eventually I want to burn a DVD and obviously retain the original 16:9 AR. How would I accomplish this? I tried reconverting to DV but it creates artifacts in the reconverted video.
In TMPGEnc Plus, the source file's aspect ratio is on the Advanced tab as "Source Aspect Ratio". Set that to "16x9 525 line NTSC". Then on the Video tab you select the output AR to "16:9 Display". If the two don't match it will convert the AR (eg, lettebox an 16:9 source into a 4:3 output).
editing or converting 24fps mpg and retain original length and playback
By MisterRPH in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2011, 23:36 -
BD --> DVD (SD) How to retain both, DTS and AC3?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2010, 18:28 -
To retain cinemascope. Audio/Video not in sync.
By smshinde75 in forum Authoring (DVD)Replies: 1Last Post: 4th Apr 2010, 13:33 -
Is it possible to retain HD Audio when converting to BD9 in BDREBUILDER
By igotafeelin in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Aug 2009, 16:42 -
Create DVD from mkv and retain size?
By elven in forum Authoring (DVD)Replies: 1Last Post: 7th Apr 2008, 06:15
