Being sick of my kids scratching and loosing dvds, I copied them all in MKV onto an external HDD which I then plugged into a WDTV. This ended up being over one hundred movies, yet it worked brilliantly. The other day I the HDD wouldn't work and when I plugged it into the computer it asked for it to be reformatted!
I've used a recovery program and copied the files onto another HDD, however most them won't work. I used MediaInfo on the broken files and it shows no details regarding the format, codec, etc only the container size.. What can I d to recover them? Any help would be greatly appreciated.
One reason I back up my BD>MKV conversions to DVD DL disc. I set their size to fit. I've already lost one 500GB HDD full of MKVs, but I have the DL discs to restore them.
What recovery program did you use? Some work better than others. When you say, 'most them won't work', not a good sign.
I would expect just a few wouldn't work if the recovery was moderately successful. Also, how big is the drive that wouldn't work?
Hi there
I used filescavenger 3.2 which allowed me to get the files off the WD 1 terrabyte onto another. I think I'm screwed, but I was hoping maybe there's a way to recover the codec info back into the files. -
Basically, i could watch movies one day, the next day the drive isn't being recognised. Plug it into a computer and it wants to be formatted and I can't see the files in it. oh well.
Why won't my TV play certain MKV files?
By MrFriendly in forum DVB / IPTVReplies: 27Last Post: 24th May 2016, 15:00 -
mkv-files won't play on my LG PK350 plasma-TV after muxing subtitles
By cbarduck in forum Newbie / General discussionsReplies: 14Last Post: 4th Oct 2012, 12:27 -
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 23:15 -
Blu-ray .mkv files won't play both audio and video at the same time
By birdbrainblue in forum Software PlayingReplies: 2Last Post: 20th Jan 2012, 07:42 -
MKVs Won't Play from External HDD
By encodedprocess83 in forum Software PlayingReplies: 4Last Post: 10th Dec 2008, 02:02
