Ok yes I have searched the forum and yes I have found but they are all old posts like 3 years past and I thought there might be something new. Short of using Premiere or Pinacle is there a software that allows me editing a video to select a region of the video and blur it out? Yes I mean select. I tried AVS with it's scripting editor and though it is quick and easy I still have to select regions using x,y coords. Using Vdub and it's filters is the same thing, I have to manually enter the coords to blur. This is fine I can figure that out. The problem is it like most people moves in the video so every other frame I have to move it also.
Any recent software that does this, like I said allows me to select not scripting. I know vdub will but I have to enter manually and takes too long for what I need any ideas?
Thanks in advanced.
Shucks! ha ha. So does pinnacle studio 11 do this fully? I know it does the blurring but does it do object tracking that anyone knows of? If it does tracking that might be worth it then hmmm
Oh also. Let's say no tracking auto. Is there software that does just the frame by frame blur but where I don't have to insert the coords? Where I can select with mouse? That would at least make it faster.
Unwanted blur when rendering
By Notuom in forum EditingReplies: 16Last Post: 11th May 2009, 19:25 -
youtube video is very blur!
By yunakokimama in forum Video ConversionReplies: 1Last Post: 14th Oct 2008, 16:16 -
can HD or Blur Ray be recorded?
By Ade007 in forum DVD RippingReplies: 4Last Post: 11th Feb 2008, 19:22 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 08:52 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 11:49
