Hello.
I had a house-mate of mine make a back-up. The trouble is that the x264 / mp4 that we now have is 2:35 and looks stretched width-wise, when it ought to be 1:85.
For avi files, the solution is simple - MPEG4 Modifier. Load the file, tick the desired Display AR and then save.
It doesn't seem that easy for a x264 file. Looking around this site, I found some older threads on Yamb, as a GUI for MP4Box. My brain started to bake and so no progress was made.
Rather than re-rip, I would like to understand this problem and be able to fix it, so that I may be able to fix any future mistakes.
Can anyone suggest how I can most easily / simply change the Aspect / Display AR of an MP4 (x264) - from 2:35 to 1:85?
Thanks!
Yamb supports pixel aspect ratio flags. You'll have to know the pixel aspect ratio though. I suspect you're video is flagged 16:9 PAR when it should be 4:3 PAR.
Alternatively, you could mux the video into an MKV container which supports display aspect ratio flags. If you know the video is supposed to display as 16:9 you can just set the DAR to 16:9.
Using VirtualDub to Fix Aspect Ratio
By Djard in forum EditingReplies: 15Last Post: 10th Sep 2013, 18:33 -
How to fix avidemux error when h.264 is used
By skorpinok in forum Video ConversionReplies: 0Last Post: 15th Jul 2011, 11:00 -
Corrupt MP4 (H.264) fix?
By Xplaya in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2010, 18:04 -
Fix H.264 video clip? (another hauppauge HD PVR)
By unplug in forum EditingReplies: 0Last Post: 2nd Sep 2008, 00:39 -
Can't get the aspect ratio on X.264 right!
By Gew in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2008, 09:48
