Results 1 to 1 of 1
    Jul 2009
    Netherlands
    Hello.
    Im getting this error message when I render a comp in After Effects 6,its not every time but at least 75% of the timewhich is enough to cause problems which are when I laod a sound file (WAV) into the time line and then try to render the scene,the scene will render normally untill it reachs the sound file and then stops and the result is the error message
    After Effects error: opening sound component (-2166)
    It appears when Im rendering the comp in A Effects as QUICK TIME uncompressed,and even with AVI UNCOMPRESSED
    Im working with XP--service pack 3
    AMD Quad core
    Quick time Pro installed latest version
