Hi i want to duplicate video layer add Gaussian blur and median blur and apply blend mode to color, is that possible? if it is it will be a life savior so i can do all my editing in avisynth rather than using photoshop, if so what will be an example thanks.
all i wanna do is remove color noise but photoshop takes ages.
I'll let someone else suggest AVISynth filtering options. But I would try a representative clip in VirtualDub as it can duplicate a lot of the AVISynth filters, though at a much slower filtering speed and maybe not as versatile. But it would give you an idea what is possible and a lot easier to set up than AVISynth, unless you understand code and the filters themselves. If you apply a blur, that really doesn't do much for removing color noise. You might try NeatVideo as it does fairly well with noise filtering. Most times, color noise is not easy to correct. I've resorted to converting to a B+W video to eliminate it and get a viewable video.
Lots of VD filters here: http://www.thedeemon.com/VirtualDubFilters/ If you can do something with those, then a AVISynth filter chain would be faster and probably more flexible. ColorMill2 is also handy for correcting color after noise filtering in VD. -
thanks but neat video doesnt remove color noise like photoshop does but i was wondering if i could repeat what i do in photoshop ( same technique) in virtualdub or avisynth. or forget about color noise all i want to do is duplicate layer then add Gaussian blur and median blur then blend or overlay to color.
Could you post a short representative video clip of the color noise? Then someone here may be able to suggest a method of cleaning it up. We have a 30MB cap on attachment size, but even ten seconds of video may be enough. Preferably in the original format.
It does, huh. It's also really good for certain old TV series and movie DVDs with splotches of purplish-red discoloration everywhere. Drawback is a bit of loss of red color in general, but it's a small price to pay.
Auto color a la Photoshop
By omnimoeish in forum RestorationReplies: 62Last Post: 13th Jan 2012, 16:56 -
Frame rate conversions: How to blend select frames in AVISynth?
By SDeC in forum Video ConversionReplies: 9Last Post: 23rd Jun 2010, 09:16 -
Avisynth Color Matrix?
By Mdoodm1000 in forum Video ConversionReplies: 8Last Post: 5th Jun 2010, 12:52 -
remove color (paintshop/photoshop)
By themaster1 in forum RestorationReplies: 3Last Post: 15th Nov 2008, 02:36 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 21:52
