is there any tool or application than can convert from bluray to dvd include menus ?
	No. You could try multiavchd and see how much it includes but no menus.
	ok, if i convert only the movie to dvd
 what tool i've to use to get it out the menus ? so i can author it manually to dvd ?
	Either use tmpeg 4.0 or use megui to make a avs file and pipe it to hcenc and author the output wit dvdauthorgui if all else fails read the manual
	no, i mean , these blu-ray have menus right , i want to use this menus, i didn't want to make the new one
 what tools should i use, to get this menus ? hope you can understand what i mean
	There is no way to do a direct menu transfer. You will have to author a new menu. You can conver the subs and get the chapter info though if all else fails read the manual
	Bluray menus allow java programming, and a lot of interactivity that simply cannot be mimicked under the DVD specification. At some point someone might create a tool to convert a Bluray menu into a still DVD menu, but honestly, what does that really save you ? Read my blog here.
  Adding new M2TS file to existing bluray with menus intactBy tanzer26 in forum Authoring (Blu-ray)Replies: 6Last Post: 25th Jun 2012, 08:45
  Media player for mom? PAL DVDs, Bluray ISOs with menus, automatic ripping?By Asterra in forum Media Center PC / MediaCentersReplies: 4Last Post: 9th Dec 2011, 17:52
  Which software to author BluRay and create menus?By eummagic in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2011, 04:16
  Preview bluray/avchd dvd menus,chaptersBy vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2010, 14:55
  How do I include wmv to a dvd with mpeg2?By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 21:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
