I am trying to edit .mp4 files from a digital solid state HD camcorder @ 1080i/60 using Vegas or Premiere Elements. Everything works fine if its in 720 format, but 1080i I have a few problems, perhaps someone can shine some light.
the 1080i mp4 files play fine untouched in WMP
But...
In Vegas, when importing and previewing without doing anything, the audio sync is off and the video is often choppy (using approx 30-40% cpu). Same results for a rendered file uncompressed or compressed.
In Elements, the aspect ratio is always stretched out, even if using a 1080i project template.
I tried using vegas, elements or i hate to say it, pinnacle. The PC is more than enough to meet the sys requirements for this type of job. Any advice would be much appreciated.
System:
quad core AMD 2.6ghz
4 g ram
2 vid cards (2gb memory each I think)
2 monitors hooked up and currently set to 1920x1080
windows 7 64bit
Below is the list of installed codecs:
0#Direct Show#Nero Audible Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeAudible.ax#-#4,5,13,0#ok
1#Direct Show#Pinnacle Real Media Renderer 2#C:\Program Files (x86)\Pinnacle\Shared Files\RealVideo\PCLERMRenderer2.ax#-#1,0,0,79#ok
2#Direct Show#MainConcept (Adobe2) MPEG-4 Video Decoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2m4vd.ax#-#7.5.0.46599 2008-05-27#ok
3#Direct Show#Nero Subpicture Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSubpicture.ax#-#4,5,13,0#ok
4#Direct Show#MainConcept (Adobe2) Layer II Audio Decoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2l2ad.ax#-#7.4.0.46599 2008-05-04#ok
5#Direct Show#Nero Scene Detector 2#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSceneDetector.ax#-#4,5,13,0#ok
6#Direct Show#Nero Stream Buffer Sink#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSBE.ax#-#4,5,13,0#ok
7#Direct Show#Nero Subtitle#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSubtitle.ax#-#4,5,13,0#ok
8#Direct Show#ATI Ticker#C:\Program Files (x86)\ATI Technologies\ATI.ACE\Graphics-Previews-Common\Ticker.ax#-##ok
9#Direct Show#Nero3D Video Filter#C:\Program Files (x86)\Common Files\Ahead\Lib\NSG_dxFilter.dll#-#1, 5, 2, 0#ok
10#Direct Show#DV Scenes#C:\Program Files (x86)\Nero\Nero 7\Nero Vision\NVDV.dll#-#3, 0, 3, 0#ok
11#Direct Show#Pinnacle MPEG Layer-1/2 Audio Decoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
12#Direct Show#Pinnacle(dicas) H263 Video Encoder#C:\Program Files (x86)\Pinnacle\Studio 14\Programs\pcleH263videnc.ax#-#2.3.277.0#ok
13#Direct Show#Screen Capture filter#C:\Windows\SysWOW64\wmpsrcwp.dll#-#12.0.7600.16385 (win7_rtm.090713-1255)#ok
14#Direct Show#Track2Filter#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\Track2Filter.dll#-#8.0.0.0#ok
15#Direct Show#Nero FTC#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeFTC.ax#-#1, 0, 0, 0#ok
16#Direct Show#Microsoft DTV-DVD Video Decoder#C:\Windows\SysWOW64\msmpeg2vdec.dll#-#6.1.7140.0 (fbl_multimedia(bld4act).090528-1604)#ok
17#Direct Show#MainConcept (Adobe2) AMR Decoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2amrd.ax#-#7.3.0.46599 2008-05-27#ok
18#Direct Show#Pinnacle(dicas) MPEG-4 Video Decoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\pclempeg4viddec.ax#-#1.9.277.0#ok
19#Direct Show#MainConcept (Adobe2) MPEG Audio Decoder#C:\Program Files (x86)\Common Files\Adobe\DVA\COM\Rel1\ad2mcdsmpeg.ax#-#1, 0, 0, 75#ok
20#Direct Show#MainConcept (Adobe2) MPEG Video Decoder#C:\Program Files (x86)\Common Files\Adobe\DVA\COM\Rel1\ad2mcdsmpeg.ax#-#1, 0, 0, 75#ok
21#Direct Show#MainConcept (Adobe2) MPEG-2 Video Decoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2m2vd.ax#-#7.5.0.46599 2008/05/21#ok
22#Direct Show#AC3 Parser Filter#C:\Windows\SysWOW64\mpg2splt.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
23#Direct Show#Nero Resize#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeResize.ax#-#4,5,13,#ok
24#Direct Show#Pinnacle(dicas) MPEG-4 Audio Decoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\pclempeg4auddec.ax#-#1.6.277.0#ok
25#Direct Show#Nero AV Synchronizer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeAVSync.ax#-#4,5,13,#ok
26#Direct Show#VBI Codec#C:\Windows\SysWOW64\VBICodec.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
27#Direct Show#Nero Audio Stream Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeRender.ax#-#4,5,13,0#ok
28#Direct Show#MPEG-2 Splitter#C:\Windows\SysWOW64\mpg2splt.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
29#Direct Show#Closed Captions Analysis Filter#C:\Windows\SysWOW64\cca.dll#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
30#Direct Show#Microsoft MPEG-2 Video Encoder#C:\Windows\SysWOW64\msmpeg2enc.dll#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
31#Direct Show#Nero Digital AVC Audio Encoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDAud.ax#-#4,5,13,0#ok
32#Direct Show#Nero Digital AVC File Writer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4,5,13,0#ok
33#Direct Show#Nero Digital AVC Video Enc#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDVid.ax#-#4,5,13,0#ok
34#Direct Show#Nero Digital AVC Null Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4,5,13,0#ok
35#Direct Show#Nero Digital AVC Muxer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4,5,13,0#ok
36#Direct Show#Nero QuickTime(tm) Video Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeQTDec.ax#-#4,5,13,0#ok
37#Direct Show#Nero3D Transition#C:\Program Files (x86)\Common Files\Ahead\Lib\NSG_dxFilter.dll#-#1, 5, 2, 0#ok
38#Direct Show#MainConcept (Adobe2) MP4 Multiplexer#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2mp4mux.ax#-#7.7.0.46599 2008-05-27#ok
39#Direct Show#MMACE ProcAmp#C:\Program Files (x86)\ATI Technologies\ATI.ACE\Graphics-Previews-Common\MMACEFilters.dll#-##ok
40#Direct Show#MainConcept (Adobe2) Layer II Audio Encoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2l2ae.ax#-#7.3.0.46599 2008-04-01#ok
41#Direct Show#Nero Digital AVC Subpicture Enc#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeNDMux.ax#-#4,5,13,0#ok
42#Direct Show#Nero Format Converter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeroFormatConv.ax#-#4,5,13,0#ok
43#Direct Show#Nero Overlay Mixer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeOverlayMixer.ax#-#4,5,13,0#ok
44#Direct Show#Nero MP4 Splitter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeMP4Splitter.ax#-#4,5,13,0#ok
45#Direct Show#HighMAT and MPV Navigator Filter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\HMNavigator.ax#-#4,5,13,0#ok
46#Direct Show#Nero Photo Source#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NePhotoSource.ax#-#4,5,13,0#ok
47#Direct Show#Pinnacle(dicas) MPEG-4 File Reader#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\pclemp4filereader.ax#-#3.1.281.0#ok
48#Direct Show#PICVideo M-JPEG 3 DirectShow Decompressor#C:\Program Files (x86)\Common Files\Pegasus Imaging\pvmjpg30.dll#-#3.0.0.12#ok
49#Direct Show#Nero Video Analyzer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeVideoAnalyzer.ax#-#4,5,13,0#ok
50#Direct Show#Nero ES Video Reader#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NDParser.ax#-#4,5,13,0#ok
51#Direct Show#Microsoft MPEG-2 Encoder#C:\Windows\SysWOW64\msmpeg2enc.dll#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
52#Direct Show#DV Source Filter#C:\Program Files (x86)\Nero\Nero 7\Nero Vision\NVDV.dll#-#3, 0, 3, 0#ok
53#Direct Show#Pinnacle MCE Multiplexer#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
54#Direct Show#Nero Audio CD Filter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeAudCD.ax#-#4,5,13,0#ok
55#Direct Show#Nero3D Text Effect#C:\Program Files (x86)\Common Files\Ahead\Lib\NSG_dxFilter.dll#-#1, 5, 2, 0#ok
56#Direct Show#Nero Video Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeVideoRenderer.ax#-#4,5,13,0#ok
57#Direct Show#Nero PresentationGraphics Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeBDGraphic.ax#-#4,5,13,0#ok
58#Direct Show#Nero InteractiveGraphics Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeBDGraphic.ax#-#4,5,13,0#ok
59#Direct Show#MainConcept (Adobe2) MPEG Demultiplexer#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2mpgdmx.ax#-#7.3.0.46599 2008-05-26#ok
60#Direct Show#SmartSound Soundtrack#C:\Program Files (x86)\SmartSound Software\Quicktracks\DirectQX.dll#-#3.09#ok
61#Direct Show#SmartSound SDS Reader#C:\Program Files (x86)\SmartSound Software\Quicktracks\SDSReader.dll#-#3.09#ok
62#Direct Show#MainConcept (Adobe2) MPEG-2 Video Encoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2m2ve.ax#-#7.4.0.46599 2008-05-27#ok
63#Direct Show#MainConcept (Adobe2) AVC/H.264 Video Encoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2h264ve.ax#-#7.4.0.46599 2008-06-11#ok
64#Direct Show#Nero Sound Processor#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSoundProc.ax#-#4,5,13,0#ok
65#Direct Show#Nero Audio Sample Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeRender.ax#-#4,5,13,0#ok
66#Direct Show#Nero Vcd Navigator#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeVCD.ax#-#4,5,13,0#ok
67#Direct Show#Nero Audio Processor#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeAudioConv.ax#-#4,5,13,0#ok
68#Direct Show#VPS Decoder#C:\Windows\SysWOW64\WSTPager.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
69#Direct Show#MainConcept (Adobe2) MPEG Push Demultiplexer#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2mpgpdmx.ax#-#7.3.0.46599 2008-07-15#ok
70#Direct Show#Nero Mpeg2 Encoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeVCR.ax#-#4,5,13,0#ok
71#Direct Show#VBI Surface Allocator#C:\Windows\SysWOW64\vbisurf.ax#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
72#Direct Show#Nero Video Stream Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeRender.ax#-#4,5,13,0#ok
73#Direct Show#MMACE SoftEmu#C:\Program Files (x86)\ATI Technologies\ATI.ACE\Graphics-Previews-Common\MMACEFilters.dll#-##ok
74#Direct Show#iTV Data Sink#C:\Windows\SysWOW64\itvdata.dll#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
75#Direct Show#Pinnacle MPEG Layer-2 Audio Encoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
76#Direct Show#iTV Data Capture filter#C:\Windows\SysWOW64\itvdata.dll#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
77#Direct Show#Nero Stream Buffer Source#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSBE.ax#-#4,5,13,0#ok
78#Direct Show#Nero PS Muxer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NePSMuxer.ax#-##ok
79#Direct Show#Pinnacle MPEG Adjust#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
80#Direct Show#Pinnacle MP3 Encoder#C:\Program Files (x86)\Pinnacle\Studio 14\Programs\PcleMP3Encoder.ax#-#9,3,2,72#ok
81#Direct Show#MMACE DeInterlace#C:\Program Files (x86)\ATI Technologies\ATI.ACE\Graphics-Previews-Common\MMACEFilters.dll#-##ok
82#Direct Show#PICVideo M-JPEG 3 DirectShow Compressor#C:\Program Files (x86)\Common Files\Pegasus Imaging\pvmjpg30.dll#-#3.0.0.12#ok
83#Direct Show#Nero Splitter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSplitter.ax#-#4,5,13,0#ok
84#Direct Show#Nero Deinterlace#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeDeinterlace.ax#-#4,5,13,#ok
85#Direct Show#DivX Video Decoder 0004#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\DivXDec.ax#-#8.1.0.12#ok
86#Direct Show#RDP DShow Redirection Filter#%SystemRoot%\system32\DShowRdpFilter.dll#-##broken
87#Direct Show#Nero File Source / Splitter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeFSource.ax#-#4,5,13,0#ok
88#Direct Show#Microsoft MPEG-2 Audio Encoder#C:\Windows\SysWOW64\msmpeg2enc.dll#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
89#Direct Show#WST Pager#C:\Windows\SysWOW64\WSTPager.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
90#Direct Show#MainConcept (Adobe2) AAC Encoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2eaac.ax#-#7.6.0.46599 2008/04/30#ok
91#Direct Show#MPEG-2 Demultiplexer#C:\Windows\SysWOW64\mpg2splt.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
92#Direct Show#MainConcept (Adobe2) AMR Encoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2amre.ax#-#7.3.0.46599 2008-05-27#ok
93#Direct Show#MainConcept (Adobe2) Dolby Digital Audio Decoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2ddad.ax#-#7.3.0.46599 2008-05-27#ok
94#Direct Show#MainConcept (Adobe2) Stream Parser#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2mpgdmx.ax#-#7.3.0.46599 2008-05-26#ok
95#Direct Show#MainConcept (Adobe2) MPEG-4 Video Encoder#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2m4ve.ax#-#7.26.0.46599 2008-03-25#ok
96#Direct Show#Nero Video Processor#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeroVideoProc.ax#-#4,5,13,0#ok
97#Direct Show#Pinnacle MPEG 2 Decoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
98#Direct Show#Nero Sound Switcher#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSoundSwitch.ax#-#4,5,13,0#ok
99#Direct Show#MPEG-2 Sections and Tables#C:\Windows\SysWOW64\Mpeg2Data.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
100#Direct Show#Microsoft AC3 Encoder#C:\Windows\SysWOW64\msac3enc.dll#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
101#Direct Show#Nero Audio CD Navigator#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeAudCD.ax#-#4,5,13,0#ok
102#Direct Show#MainConcept (Adobe2) MP4 Demultiplexer#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\ad2mp4demux.ax#-#7.7.0.46599 2008-05-27#ok
103#Direct Show#Nero Thumbnail Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeBDThumbnail.ax#-#4,5,13,0#ok
104#Direct Show#Nero Scene Detector#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSceneDetector.ax#-#4,5,13,0#ok
105#Direct Show#Pinnacle MPEG 2 Splicer#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
106#Direct Show#Nero Stream Control#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeStreamControl.ax#-#1, 0, 0, 0#ok
107#Direct Show#Nero Sample Queue#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeSampleQueue.ax#-#1, 0, 0, 0#ok
108#Direct Show#Pinnacle MPEG Demuxer#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PcleMPGDemux.ax#-#5.0.800.00 #ok
109#Direct Show#Pinnacle MPEG 2/AVC Multiplexer#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
110#Direct Show#Dump#C:\Program Files (x86)\Adobe\Adobe Premiere Elements 8.0\\plug-ins\en_US\DvFileWriter.prm#-##broken
111#Direct Show#Nero File Source#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeFileSrc.ax#-#4,5,13,0#ok
112#Direct Show#Nero QuickTime(tm) Audio Decoder#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeQTDec.ax#-#4,5,13,0#ok
113#Direct Show#Nero File Source (Async.)#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeFileSourceAsync.ax#-#4,5,13,0#ok
114#Direct Show#Nero Ogg Splitter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeOggSplitter.ax#-#4,5,13,0#ok
115#Direct Show#Pinnacle(dicas) AMR Audio Decoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\pcleamrauddec.ax#-#2.3.277.0#ok
116#Direct Show#Pinnacle MPEG 2 Encoder#C:\Program Files (x86)\Pinnacle\Shared Files\Filter\PCLEMPEGBox.ax#-#5.0.809.00 #ok
117#Direct Show#Microsoft DTV-DVD Audio Decoder#C:\Windows\SysWOW64\msmpeg2adec.dll#-#6.1.7140.0 (fbl_multimedia(bld4act).090528-1604)#ok
118#Direct Show#Nero Digital Parser#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NDParser.ax#-#4,5,13,0#ok
119#Direct Show#Nero Frame Capture#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeCapture.ax#-#4,5,13,0#ok
120#Direct Show#Nero Video Sample Renderer#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeRender.ax#-#4,5,13,0#ok
121#Direct Show#Track1Filter#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\Track1Filter.dll#-#8.0.0.0#ok
122#Direct Show#HighMAT/MPV Navigator Client Filter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\HMNavigator.ax#-#4,5,13,0#ok
123#Direct Show#Nero DV Splitter#C:\Program Files (x86)\Common Files\Ahead\DSFilter\NeDVSplitter.ax#-#4,5,13,0#ok
124#Direct Show#MainConcept (Adobe2) DV Video Decoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2dsdv.ax#-#7.7.0.46599 2008-05-27#ok
125#Direct Show#MainConcept (Adobe2) DV Video Encoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2dsdv.ax#-#7.7.0.46599 2008-05-27#ok
126#Direct Show#Enhanced Video Renderer#C:\Windows\SysWOW64\evr.dll#-#6.1.7600.16385 (win7_rtm.090713-1255)#ok
127#Direct Show#Pinnacle(dicas) AMR Audio Encoder#C:\Program Files (x86)\Pinnacle\Studio 14\Programs\pcleamraudenc.ax#-#2.3.277.0#ok
128#Direct Show#BDA MPEG2 Transport Information Filter#C:\Windows\SysWOW64\psisrndr.ax#-#6.6.7600.16385 (win7_rtm.090713-1255)#ok
129#Direct Show#MainConcept (Adobe2) AAC Decoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2daac.ax#-#7.6.0.46599 2008/04/30#ok
130#Direct Show#MainConcept (Adobe2) AVC/H.264 Video Decoder#C:\Program Files (x86)\Adobe\Elements Organizer 8.0\CAHeadless\ad2avcvd.ax#-#7.5.0.46599 2008-06-02#ok
131#Video-Codec##\msrle32.dll#vidc.mrle##broken
132#Video-Codec##\msvidc32.dll#vidc.msvc##broken
133#Audio-Codec##\imaadp32.acm#msacm.imaadpcm##broken
134#Audio-Codec##\msg711.acm#msacm.msg711##broken
135#Audio-Codec##\msgsm32.acm#msacm.msgsm610##broken
136#Audio-Codec##\msadp32.acm#msacm.msadpcm##broken
137#Video-Codec##\msyuv.dll#vidc.uyvy##broken
138#Video-Codec##\msyuv.dll#vidc.yuy2##broken
139#Video-Codec##\msyuv.dll#vidc.yvyu##broken
140#Video-Codec##\iyuv_32.dll#vidc.iyuv##broken
141#Video-Codec##\iyuv_32.dll#vidc.i420##broken
142#Video-Codec##\tsbyuv.dll#vidc.yvu9##broken
143#Audio-Codec#MPEG Layer-3 Audio Codec for MSACM#C:\Windows\SysWOW64\l3codeca.acm#msacm.l3acm #1, 9, 0, 0401#ok
144#Video-Codec##\iccvid.dll#vidc.cvid##broken
145#Video-Codec##\pvmjpg30.dll#vidc.mjpg##broken
Sam Davies - CEO Wisconsin fireworks stores
You should try to re-encode it first, before working with your video in Sony Vegas. I know there are some big problems handling mp4-files in there. You should convert it into an mpeg-layered video file and then try it again. You will see this will solve your main issue. I wouldn't recommend editing mp4-data. It's the processed video and isn't worth working with. If you got the mp4, everything is done with it.
Thank you anotherkentpaul, what app do you recommend to re-encode and into what type of mpeg?
Sam Davies - CEO Wisconsin fireworks stores -
I am recommending Tmpgenc Xpress. It's not the cheapest alternative and I am not really into open-source software that much as I could recommend any, but it works and it handles tons of video formats and codecs aswell.
I still have the same problem in finding the right cutting and editing format. I think AVI is a great export format, and so is MPEG2. If you still want to go on working with Sony Vegas, you should go the MPEG2-way.
Leave a message if you want to have any further information about Tmpgenc.
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
Tight synced audio + subtitles, poor synced video...
By goodbot in forum SubtitleReplies: 5Last Post: 13th Jul 2009, 23:59 -
Converting .rmvb to .mp4 (Audio not synced w/ video)
By mikeeeeyy in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 00:44 -
1080i video is choppy
By David97 in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2008, 12:19
