First off, I use Ripit4me for most of my ripping and anydvd for the rest, then copy to dvd to burn. I'm 100% satisfied with the results and procedures.
Two days ago we had a power outage while I was burning. Immediate coaster. Up until then copy to dvd would burn DL discs. Since then it keeps telling me that it can't burn to disc and eject's it. I've uninstalled and reinstalled numerous times, numerous versions. Same thing. Could the burner itself have been damaged?
What burning software are you using? Brand of DL media?
try using a verbatim dl. I also think burner may have been damaged so how.
What We Do In Life, Echoes In Eternity.... -
Try using IMGBURN which is freeware to use for burning DVD/CD media. As for your brands of media, they are considered LOW GRADE. Use some VERBATIM DVD+R Dual Layer media before you rule out the dvd burner becoming broken after a power surge.
Suddenly Cannot burn DVD files to DVD-Rs
By Frogde3 in forum Authoring (DVD)Replies: 6Last Post: 22nd Oct 2008, 15:55 -
What the bloody... burn speed suddenly plummits...
By Hal05154 in forum DVD & Blu-ray WritersReplies: 30Last Post: 6th Sep 2008, 01:50 -
My HP DVD Writer 840x Wont Burn !?
By ticotaz in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Jan 2008, 06:23 -
Dvd Burner Wont Copy
By Catman209 in forum DVD & Blu-ray WritersReplies: 12Last Post: 16th Dec 2007, 00:35 -
Benq DW 1650 suddenly won't burn TY02
By smitbret in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2007, 15:15
