I used DVDshrink to combine(re-author) several large segment of DVD video without compression into a 7GB DVD video.
I used Nero 6 to burn it to DL DVD, and the DVD plays the first half, and stuck at layer break(I think).
I tried imgburn, and it told me it cannot find the right place to do layer break.
please help.
I also like to find is there a menu in imgburn that I can drag the video_ts folder, and burn DVD ?
Should I use DVDdecrypter instead of imgburn ?
	If ImgBurn is saying that there is no suitable spot for layer break then it's probably right and the DVD needs to be reauthored to have one, try these:
 http://forum.imgburn.com/index.php?showtopic=6376
 https://www.videohelp.com/forum/archive/imgburn-can-t-find-a-place-for-a-layer-break-t374714.html
  DVD Players That Handle The Layer ...Break Well.By Goblin~Magnet in forum DVD & Blu-ray PlayersReplies: 8Last Post: 1st Jul 2010, 09:43
  Problem: DVDShrink > DVDDecrypter - Layer Break Issue?By Dave Stewart in forum DVD RippingReplies: 32Last Post: 27th Jun 2010, 21:18
  Burning Double Layer DVD with no Layer Break.By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26
  Trouble finding a layer break possibility for video ts fileBy Daffyd39 in forum Authoring (DVD)Replies: 15Last Post: 12th Nov 2007, 12:37
  Retail Layer Break and Imgburn Layer Break..the same?By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
