I understand that movies in standard definition are broadcast in either 480i or 480p. How can this be determined? Do I set the PVR up any differently than I would when recording a 16:9 HD movie at 1920x1080. I am assuming the SD movies will still be recorded at 1920x1080. Do these need to be resized to 720 when converted to MKV?
Don't sweat it. ALL modern HD video is digital, so I would assume that a HD PVR does exactly the same as what my SD one does - captures the original broadcast stream and stores it as-is. So whatever the program is broadcast in, that's what it'll be stored as. If the station you're recording from is exclusively SD, or has the good sense to broadcast the material at it's original size, then you'll get 480i / 480p. If they've upscaled it, then you'll get 720p / 1080i / whatever. There's nothing you have to - or even CAN - do to affect this.
If it's one that doesn't take an aerial signal but instead, e.g. a component or HDMI input, then I'd still expect it to detect the resolution of the material coming in and adjust accordingly.-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Watermark when capturing with Hauppauge HD-PVR?
By rajman in forum Capturing and VCRReplies: 4Last Post: 6th Mar 2011, 15:14 -
Hauppauge HD PVR for PC footage capturing
By Xize in forum Capturing and VCRReplies: 2Last Post: 26th Feb 2010, 11:25 -
Any OTHER S/W for Capturing a DH-PVR?
By Randall_C in forum Capturing and VCRReplies: 6Last Post: 22nd Oct 2009, 13:55 -
Viewsat PVR 7000 - Playing movies on PC
By gilray in forum Software PlayingReplies: 3Last Post: 18th Oct 2007, 10:53 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 22:46
