Here's the video clip http://www.mediafire.com/download.php?ga4yeijtcmj At 0:13 the rockets fly behind the rock and then it crashes. How can I make it sound like the rockets are coming from behind the rock? and you know when it crashes the rocks start falling how can I make it sound like that? Here's the bomb sound effect http://www.mediafire.com/download.php?vzynijkcuu3 This is the rock slide sound effect http://www.mediafire.com/download.php?oke1nzzgtte This is the rocket sound effect http://www.mediafire.com/download.php?yhzmmn2iylm This is the flying rockets sound effect http://www.mediafire.com/download.php?mqijwzm1qlk
If you are using stereo the there are a number of ways. If you have binaural in ear microphones they imitate the postioning in the real world as your ear lobe helps you position the sound , having the microphone sin ear gives the illusion of the same positioning. works best on headphones though.
apart from that there is a vst plugin that will work with most audio editors called
Prosoniq Ambisone
which allows for a variety of interesting spatial effects with stereo.
Just bouncing the mix down from 5.1 to stereo will do nothing more than pan the image across the stereo mix from left to right or whatever and will not likely give the illusion of depth.
ReactOS: The Russians Are Coming, The Russians Are Coming (Maybe?)
By CobraPilot in forum ComputerReplies: 12Last Post: 17th Sep 2011, 00:21 -
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 02:40 -
Sound only coming from subwoofer
By jeanpave in forum AudioReplies: 11Last Post: 5th Oct 2010, 01:24 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
Western Digital WD2500JB 250GB making buzzing sound
By ChapGrip in forum ComputerReplies: 1Last Post: 26th Jun 2007, 18:17
