Hi all,
I have videos from some research experiment - some are recorded with standard HD or SD PAL cameras, one is hi-speed (300fps) video from Casio Exilim F1 (I deleted some additional info which are not important):
I would like to add a time values in the video or as external subtitles to show ho fast the recorded process is (cannot say more info about our research). I am using Avidemux + some additional tools like Avisynth, Avanti etc. and we also have one Pinnacle Studio 12 (the basic version).Code:Format : MPEG-4 Format profile : QuickTime Codec ID : qt Overall bit rate : 1 392 Kbps Writing application : Casio Digital Camera Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 45mn 18s Bit rate : 1 390 Kbps Width : 512pixels Height : 384pixels Display aspect ratio : 4:3 Frame rate : 29,970 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.236 Stream size : 450 MiB (100%) Language : English
Is there any free tool which could do it? The best way would be, if I could also somehow "calibrate" the hi-speed video to show approx. real time in the titles.
any advice would be nice
thanks
Subtitles in video : detect time position
By Urban20 in forum SubtitleReplies: 2Last Post: 15th Nov 2011, 04:24 -
Adding subtitles to a video TS file
By chiburu in forum SubtitleReplies: 2Last Post: 17th Jul 2011, 15:32 -
Adding subtitles to a video - any programs out there?
By Bansaw in forum SubtitleReplies: 2Last Post: 23rd May 2011, 17:34 -
Adding timecode data to a VP8 video at encode-time
By ilya.lissoboi in forum ProgrammingReplies: 0Last Post: 29th Apr 2011, 06:43 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53
