hello
I am using winavi 10 to convert vob files to single avi file. I have used this process in the past and it has worked fine up until now. I have installed and uninstalled winavi several times. I have tested the vob file and the sound works. The program actually converts the file and I get the picture fine but no audio. I have installed several codec packs but still no luck. I have tried other converters but I really like this one - when it works? I am using windows XP. I am using DVD shrink and decryter to obtain the vob files. I have searched the web and win site for answers but also no luck.
Can anyone help please?
Thanks in advance
Thanks Baldrick
Yes I have also tried same with open DVD. Still no audio. (Any other ideas?)
Thanks for the list of the other programs though. Its just very frustrating as I do like the winavi converter. I also get annoyed when I can't work something like this out. Its probably a very simple solution which will make it more annoying.
Thanks again. -
Have you tried disabled any audio track in dvd shrink? Or not disable when you use it.
Just had a look through preferences in shrink and can't find any options to disable audio?
If you choose title and look under the compression settings, see
Try just keep one audio track.
AVI to VOB Converter??
By ChevGirl101 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2009, 16:39 -
The best free avi to vob converter
By mmmipa in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2008, 18:28 -
needing vts/ vob to avi converter
By sylvester243 in forum Video ConversionReplies: 1Last Post: 11th Oct 2007, 00:42 -
winAVI video converter - problem with audio
By mahdlo in forum AudioReplies: 6Last Post: 5th Oct 2007, 01:39 -
Avi To Vob (Best Quality Converter)
By masterpkg in forum Video ConversionReplies: 3Last Post: 22nd Jun 2007, 09:56
