hi all,
i've got some hd sources but i want to convert them to avi files, im converting the audio fine to cbr mp3 320 (not to fussed on sound quality since it's only coming out of tv speakers).
anway im converting them so they will play on many different media players in the house, and all play mp3 sound and seem to like xvid and divx 6/7.
which is best to use thou, i'm keeping the full h.d. resolution when converting, and never really had much problems using xvid before, but when i seem to use divx 6/7, on playback it seems to stutter sometimes (jump frames).
what are your views on using xvid or divx for this ?
Xivd gives slightly smaller files when using constant quality encoding, slightly less macroblocking with bitrate based encoding. But the differences aren't big. One place where you have to be careful with Xvid when using constant quality (quantizer) encoding: it ignores the bitrate cap of the currently selected profile. So you can end up with bitrate peaks that are too high for some players.
thanks for the info, i'll see what the results are like for xvid
Avoid using Xvid's GMC. It uses a three warp point method that no hardware Xvid decoder supports. Divx uses a single warp point GMC which some hardware decoders support. But, for maximum flexibility, I would avoid that too. GMC rarely helps compression much anyway. Also, Quarter Pixel (QPEL) isn't supported by most older hardware decoders. You may want to avoid that too.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
sudden vdub sync problems when converting hd sources
By uk_dan2k in forum Newbie / General discussionsReplies: 10Last Post: 8th Feb 2008, 17:37 -
Converting DV AVI to xVid AVI (with AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 01:56 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
